If an unpartitioned hard drive is installed in a PacketShaper, it will cause the appliance to crash during bootup.
A crash log similar to the following will be produced in this situation:
Loading.................................................................................................................................................................................................................................................................................................................................................................................................................................................
PacketShaper v8.3.1g1 2008-05-22,
died on Tue Oct 12 18:15:13 2010 GMT (Custom)
(Tue Oct 12 18:15:13 2010 GMT)
model (rev A), s/n , shaping:BYPASS
CPU Brand: GenuineIntel Speed: 3593 MHz (measured)
<undetermined>
Firmware: 02/06/06
Running Task: ROOT
001 [0000001.0000] A: ipInitVirtualIface: installed NI for ip address 2 7f000003 ffffff00
002 [0000001.0000] A: niInit: initializing interface
003 [0000001.0000] I: gbitDeviceInit: bus=5, dev=8, io=d0320004, irq=5
004 [0000001.0000] I: dioBoardRev: Board Type is M1100 (rev A)
005 [0000001.0000] I: gbitDeviceInit: bus=5, dev=8, io=d0340004, irq=10
006 [0000001.0000] I: gbitDeviceInit: bus=3, dev=4, io=d0220004, irq=10
007 [0000001.0000] I: gbitDeviceInit: bus=3, dev=4, io=d0240004, irq=11
008 [0000001.0000] A: niInitVirtual: initializing interface
009 [0000001.0000] Standard output device initialized.
010 [0000001.0000] Psedo device initialized.
011 [0000001.0000] System clock initialized.
012 [0000001.0000] W: Change timer- 10 per msec, tick incr = 1
013 [0000001.0000] in firstTaskStartCallout
014 [0000001.0001] A: tzLocalTimeSetCom: date 7da0a0c, time 120f0d
015 [0000001.0002] System time initialized.
016 [0000001.0041] A: utlAllocateMemory: ptr=7ff8da90, name=IDE_PRD, num=2, size=24
017 [0000001.0041] I: IDEInit: 1.0: Unit:1 not detected. rc: 1009000e
018 [0000001.0160] A: utlAllocateMemory: ptr=7ff6da90, name=IDE_PRD, num=2, size=24
019 [0000001.0160] I: IDEInit: 1.0: Unit:3 not detected. rc: 1009000e
020 [0000001.0481] Flash Disk initialized.
021 [0000001.0482] I: dioBypassClose: closing bypass
022 [0000001.0482] I: nicSuspend: called for nic0, but not ready
023 [0000001.0482] I: nicSuspend: called for nic2, but not ready
024 [0000001.0482] Processor fault 0: divide by 0
PacketShaper hard drives must be correctly partitioned and formatted before they can be recognized by the PSOS operating system used on PacketShapers.
A correctly partitioned and formatted hard drive would have four partitions which look like this:
Partition Type Size Primary/Logical Beginning Cylinder Ending Cylinder
1 FAT16 2047MB Primary 0 260
2 FAT16 2047MB Primary 261 521
3 FAT16 2047MB Primary 522 782
4 FAT16 1890MB Primary 783 1023
