What does the ProxySG 9000 power and configuration LED colors mean?
The power and configuration LED is amber. What does that mean?
The power and configuration LED is blinking between green and amber. What does that mean?
The power and configuration LED is solid green. What does that mean?
The power and configuration LED (the LED closest to the power button) has three different states and two different colors. The table below will give a description of what the various lights mean. The photograph at the bottom of the page will show you what LED is being described.
System Status | LED Status | Description | Action to be taken |
System powered on, OS not loaded | Amber | LED lights up amber while the appliance is booting | No action needed |
System powered on, OS loaded, but system not configured | Blinking between green and amber | Once OS load completes, the LED will blink from green to amber while the appliance is not configured | Need to configure the system to turn it to green |
System powered on, OS loaded, system configured | Solid green | Once the appliance is configured, the LED will turn to solid green | No action needed |
