The upper critical fan speed values on my Proxy AV appliance are skewed after an upgrade
Article ID: 167000
ProxyAV Software - AVOS
The threshold values for the fan sensors on my AV1200 & AV1400 devices (so far) have not normal after I upgraded from 3.3.1.2 to 3.4.1.1.
All values display as "0". After a software reboot, the current values start showing normal values, but the upper critical values for the Fan Speeds (RPM) are very high!
Bug was raised #173577 and was fixed in ProxyAV 3.4.1.4.
