Sky interface will no longer load on ProxySG
Article ID: 166927
ProxySG Software - SGOS
It is possible that due to network restrictions or upgrade history, that the Sky UI is not present or corrupted. To restore:
From enable mode on the command line:
ProxySG#config t
Enter configuration commands, one per line.  End with CTRL-Z.
ProxySG#(config)ui
ProxySG#(config ui)reset
Resetting UI to bound system version...
 ok
