How to schedule a reboot on Edge SWG (ProxySG) appliance
Article ID: 166483
ASG-S200 ASG-S400 ASG-S500 SG-S200 SG-S400 SG-S500 ISG Proxy
You want to reboot an Edge SWG (ProxySG) appliance at a specific time.
The Edge SWG (ProxySG) appliance doesn't offer a way to schedule a reboot, but if you are using Director (a Blue Coat appliance that manages Edge SWG (ProxySG) appliances), you can write a script to schedule a reboot.
  1. Log on to the CLI.
  2. Issue the following commands:
    ProxySG>
    ProxySG>en
    Enable Password: <your_enable_password>
    ProxySG#
    ProxySG#restart regular
  3. In the Director Management Console, on the Jobs tab, schedule a job to execute the script against any Edge SWG (ProxySG) appliance or any time you want it to run.
