This article contains the instructions on how to view .LOG files and convert them into human readable format (CSV, HTML, or generic) for Symantec Protection Engine (SPE) versions 7.8 and newer.
SPE 9.x, 8.x,or 7.8
The logconverter utility included with Protection Engine can convert the .LOG files into human readable format. It is located in <install dir> on Windows and <install dir>/bin on Linux. <install dir> is the following by default depending on the Operating System:
/opt/SYMCScan/bin/
logconverter must be run from the bash shell on Linux or the cmd prompt on Windows.
Syntax:
logconverter -[c|h] [Path/To/.LOG/file]
Flag Options
c - Output will be in CSV format
h - Output will be in HTML format
Specify up to one flag option. Without a flag, logconverter will output generic human readable text. Output can be saved to a file by redirecting the output to a file.
Example - Linux HTML:
./logconverter -h ../log/SSE20230531.log > log.html
Example - Windows CSV:
.\logconverter.exe -c log\SSE20230601.log > log.csv
Example - Windows Generic:
.\logconverter.exe log\SSE20230602.log > log.txt
Legacy version?
The logconverter.exe also works on SPE legacy version 7.5. However, SPE 7.5 on Windows is installed to the following default installation location:
C:\Program Files (x86)\Scan Engine\
