Symantec Protection Engine crashes and will not start. Shows this error:
"Windows could not start the Symantec Protection Engine service on Local Computer.
The service did not return an error. This could be an internal Windows error or an internal service error.
If the problem persists, contact your system administrator."
The Report.XML file has become corrupt. To verify this look in the log: SymantecProtectionEngineAbortLog.txt located in the protection engine working directory: C:\Program Files (x86)\Symantec\Scan Engine
Similar entries will be in the log:
2017/02/10-07:06:42 301 XML path not found : report.xml:/report/SinceInstall/VirusFound/@value. 2017/02/10-07:06:42 0 Symantec Protection Engine is shutting down; logs may contain more information
*Note: On Symantec protection engine 7.8, there is no web console. In this case make copies of all the XML files in the Symantec protection engine working directory: C:\Program Files (x86)\Symantec\Scan Engine (/opt/SYMCScan directory for Linux). Reference these files for configuration after installing Symantec protection engine 7.8 again
