In OneClick when I right click a device and select telnet or SSH can I change where this communication is initiated from?
Article ID: 16310
Spectrum Network Observability
Release:
Component:
From OneClick you can connect to devices using telnet or SSH by right-clicking the device and then selecting one of these options.
You can change where this communication is initiated by using the following options:
1.      Connect to the device through OneClick web server and Spectroserver.
2.      Connect to the device through Spectroserver.
3.      Connect to the device directly
This option is set via OneClick > View > Preferences > scroll down on right of screen to “Topology Tab > Telnet / SSH Connection Type”
Please reference the "Set OneClick Preferences" section of the documentation for more information.
1558687994181000016310_sktwi1f5rjvs16fhn.png get_app
