The following packages are not removed after the upgrade from SMP 7.5 SP1 HF5 to SMP 7.6:
The above packages do not synchronize to Package Servers after the upgrade to 7.6. The problem is most or all of them have attributes and item references that make them difficult to delete manually via the Management Console UI.
An example of an error seen in the NS operational logs:
Failed to get manifest for c72e1ab5-f300-4e8c-88ca-baf90b5b4e46: System.IO.DirectoryNotFoundException: Could not find a part of the path 'D:\Program Files\Altiris\Notification Server\NSCap\bin\Win64\x64\Symantec Endpoint Protection\AvInventory'.
Attached to this document is a SQL script that can be used to purge these packages from the Symantec_CMDB. Please contact Support to get this script. Steps to implement the solution are as follows:
