Power Supply entry on System Status page shows "Failure" in the GUI for Symantec Web Gateway (SWG)
Article ID: 162253
Web Gateway
Power Supply column shows "Failure" in the GUI for Symantec Web Gateway (SMG).
Issue might occur on following appliance models:
SWG8490 (Dell PowerEdge R720)
Power Supply redundancy disabled in the BIOS of the appliance.
Enable power supply redundancy in the BIOS or iDRAC.
Steps to enable via BIOS:
1. Boot the system, and press F2 for setup
2. Select "iDRAC Settings"
3. Select "Power Configuration"
4. Under "Power Supply Options", check the setting "Redundancy Policy", if it says <not Redundant>, it should be changed to <Input Power Redundant>
5. Reboot the system to fully apply the change.
Steps to enable via iDRAC:
1. Go to Overview -> Server -> Power/Thermal
2. Select "Power Configuration" tab
3. Select "Power Configuration" sub-tab
4. Select "Power Supply Options" section
5. Under "Redundancy Policy" if you see "Not Redundant", switch to "Input Power Redundant"
6. Reboot the system to fully apply the change
