You wish to have a list of steps and packages that need to be installed prior to installing Symantec Protection Engine (SPE) 7.5.x in order to ensure that it works correctly.
The following packages need to be present on the Linux system prior to installing SPE 7.5.x:
n.b. Some of these packages may already be present depending on the exact OS build and version used. The Yum installer will inform you if this is the case.
In addition, a 32 bit Oracle Java Runtime will need to be installed prior to installing the product. If installing the the user interface.
Lastly, modifications may need to be made to the Linux Firewall in order to ensure that a connection can be made to the SPE server on ports 8004 and 8005.
Applies To
This procedure has been successfully tested on the following platforms with a "Basic Server" OS installation:
