Advanced Settings on Network Monitor for Endace
Article ID: 160572
Data Loss Prevention Network Monitor
What are the configuration parameters for enabling a Endace card on a Symantec DLP Network Monitor
There are several configuration items in the Advanced Server Details that will affect Monitor installations with Endace cards.
PacketCapture.IS_ENDACE_ENABLED uses the value 'true' to enable a dag card.
  • Any new installation should set PacketCapture.IS_ENDACE_ENABLED to the value 'true' to enable an Endace card.
  • Any upgraded system with an endace card should continue to work correctly without altering any settings.
The other three directives involve defining the path for the Endace drivers.
PacketCapture.ENDACE_BIN_PATH
default should be:
For Windows:
 %dagpath%
For Linux:
/usr/local/bin
PacketCapture.ENDACE_LIB_PATH
default should be:
For Windows:
%dagpath%\..\lib
For Linux:
/usr/local/lib
PacketCapture.ENDACE_XILINX_PATH
default should be:
For Windows:
%dagpath%\..\xilinx
For Linux:
/usr/local/dag/xilinx
NOTE:  %VAR% variables CANNOT be used for the parameters
NOTE: PacketCapture.IS_INPUT_SOURCE_FILE has been deprecated for enabling a dag card in 8.0.
