PDS Problems to upgrade model from 8.1 to 8.7 CPF3204 errors running YAPLMDLCHG
Article ID: 16022
CA 2E
CPF3204 errors upgrading from 8.1 to 8.7 running YAPLMDLCHG
I am seeing this error message in the output when running YAPLMDLCHG
CPF3204 Diagnosmeddelande 40 17-10-03 09:04:50,725680 QDBCRTME QSYS 2026 QLICRDUP QSYS
Meddelande . . : Cannot find object needed for file YMDLLST10L in YAMDL.
Cause . . . . . : Either library YAMDL or member YMDLLSTRFP or file
YMDLLSTRFP in library YAMDL was not found.
What could cause this?
AS400 Iseries
The file YMDLLSTRFP was missing the standard empty member YMDLLSTRFP.
To solve this: add member YMDLLSTRFP to file YMDLLSTRFP and try your YAPYMDLCHG
again.
