ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Symantec Help does not restart after it reboots the computer
Article ID: 159286
Endpoint Protection
Symantec Help does not restart after it has rebooted the computer.
To manually restart Symantec Help, follow one of the following methods:
Use Task Scheduler
  1. Open the Task Scheduler
  2. Look for a task in the task scheduler root folder named “Symantec Help (relaunch)”
  3. Manually start the task
Use the command line
  1. Open the temp folder (%temp%)
  2. Locate both the most recent .SdDb file and the most recent folder that begins with “STSFX”
  3. Open a command prompt and type the following:
    cd %temp%\STSFXnnnn
    Note: Replace “STSFXnnnn” with the actual folder name.
    SymDiag.exe -relaunch ""
    Note: The SymDiag.exe command does not accept environment variables in the SdDb path)
