ProcessManager portal will not load and 500.19 Internal Server Error is returned
Article ID: 159245
Workflow Solution ServiceDesk
 The error is stating there is duplicate 'uri' section defined.
 There is a duplicate 'uri' section defined
 Default App pool with Workflow virtual directories was configured with .net Framework Version v4.0.
Right-click App pool > Advanced Settings.
In .NET Framework Version dropdown list choose v2.0 version and click OK.
Run iisreset.
Relaunch ProcessManager portal
Applies To
ServiceDesk/Workflow  7.1 SP2
Workflow 7.1 SP2 MP1
ServiceDesk 7.5 GA, MP1, SP1
Workflow 7.5
