ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Symantec Protection Engine (SPE) 7.0.x does not show Help on the web management console
Article ID: 158686
Scan Engine
You log on to the Symantec Protection Engine (hereafter "SPE") 7.0.x web management console. You navigate through the page, and click (?) icon shown at the top right-hand corner to get the information on that page. Although a web page pops up, the page is blank.
Help's HTML file name available on the system is different from that of the requeted from the web management console.
Follow the following steps and change the help file HTML's file name.
  1. Log in to your SPE host as root via local terminal or SSH.
  2. cd to <SPE_Installation_directory>/bin/html/english/help/
    By default, this localtion is /opt/SYMCScan/bin/html/english/help.
    # cd /opt/SYMCScan/bin/html/english/help
  3. Rename the file "SSEHelp.html" to "SSEhelp.htm".
    # mv SSEHelp.html SSEhelp.htm
Applies To
  • Solaris
  • Linux
