ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
DS 7.5 - Power Control tasks do not work properly while client machine is in Automation
Article ID: 158532
Deployment Solution
 When issuing command "Power Control" Shutdown or Restart to client which is in Automation - the task will be executed according to the Console - but client will stay in automation.
 unknown at this time
For WinPE - If Shutdown is required you can use Run Script command with "shutdown -s -f -t 5" which will shutdown client machine.
For LinuxPE - you can use Run Script "shutdown -s now /y"
For the Restart it's recommended to use "Boot To" task with specifying the environment where clients needs to reboot (Production)
Applies To
 DS 7.5
WinPE 4.0
LinuxPE
