Issue: 1
After installing / upgrading to SMP 7.5 the following filters may be empty when computers without pcAnywhere should be listed in them.
"Windows Computers with no pcAnywhere Plug-in Installed"
"Macintosh Computers with no pcAnywhere plug-in Installed"
"Linux Computers with no pcAnywhere plug-in Installed"
Issue: 2
After upgrading from SMP 7.1 SP2 to SMP 7.5 the following filters may be empty when computers having older version of pcAnywhere should be listed in them.
"Windows Computers requiring pcAnywhere Plug-in Upgrade"
"Macintosh Computers requiring pcAnywhere Plug-in Upgrade"
"Linux Computers requiring pcAnywhere Plug-in Upgrade"
Issue: 1
There would be no error observe. However, results of the above filters are empty.
Issue: 2
Logs similar to the following may also be seen in the NS logs.
Error delta updating collection 'e397b6ae-ad14-4d40-be03-8840fe824235':
Altiris.NS.StandardItems.Collection.AeXInvalidCollectionQueryException: Data Source failed to run. --->
Altiris.DataSource.Exceptions.DataSourceRunException: An unexpected SQL error occurred when running the RawSqlDataSource: 'Windows Computers Requiring pcAnywhere plug-in Upgrade' (e397b6ae-ad14-4d40-be03-8840fe824235) --->
System.Data.SqlClient.SqlException: Invalid length parameter passed to the LEFT or SUBSTRING function.
