The following SQL script will traverse an Altiris database and find all tables in which a specified GUID appears. It reports both the table and the column. The only requirement is to change the value of the guid being searched (Under the line that reads "Enter Search Guid here").
ITMS 8.x
In SQL Management Studio please run the following SQL Query and make sure to enter the GUID you are searching for where indicated in the query:
declare @searchvalue uniqueidentifier
--Change the GUID below. Example: {AA7E70B7-6C1E-4DA0-8D32-0097E45B02A9}
set @searchValue = '{Enter Your GUID Here}' --Enter your the GUID here
--Do Not Change Anything Below This Linke
if object_id('tempdb..#results') is not null drop table #results
create table #results (TableSchema sysname, TableName sysname)
declare @sql nvarchar(4000)
declare @cursor1 cursor
declare @tablename sysname
declare @tableschema sysname
declare @cursor2 cursor
declare @columnname sysname
declare @searchFields nvarchar(4000)
set @cursor1 = cursor for
select t.TABLE_SCHEMA, t.TABLE_NAME
from INFORMATION_SCHEMA.Tables t
where t.TABLE_TYPE = 'BASE TABLE'
and exists (
select * from INFORMATION_SCHEMA.Columns c
where c.TABLE_NAME = t.TABLE_NAME
and c.TABLE_SCHEMA = t.TABLE_SCHEMA
and c.DATA_TYPE = 'uniqueidentifier'
open @cursor1
while 1=1 begin
fetch next from @cursor1 into @tableschema, @tablename
if @@fetch_status <> 0 break
set @searchFields = ''
set @cursor2 = cursor for
select c.COLUMN_NAME
where c.TABLE_NAME = @tablename
and c.TABLE_SCHEMA = @tableschema
open @cursor2
while 1=1 begin
fetch next from @cursor2 into @columnname
set @searchFields = @searchFields + ', ' + quotename(@columnname)
end
set @searchFields = substring(@searchFields,3,len(@searchFields))
set @sql = ' insert #results'
+ ' select '''+@tableschema+''','''+@tablename+''''
+ ' from '+quotename(@tableschema)+'.'+quotename(@tablename)
+ ' where @searchValue in ('+@searchFields+')'
print @sql
exec sp_executesql @sql, N'@searchValue uniqueidentifier', @searchValue
end
select * from #results
