zIIP usage info for CA 1 Tape Management and CA Copycat.
Article ID: 15785
CA 1 Tape Management CA 1 Tape Management - Copycat Utility CA 1 Tape Management - Add-On Options
Do CA 1 Tape Management and CA Copycat use zIIP processors?
Release: 12.6 and 14.0
Component: 1
CA 1 Tape Management and CA Copycat don't use the zIIP processors.
