After you update an unattend file that is already being used in imaging jobs the jobs don't use the updated unattend file.
When you create a job the current unattend file is saved into the Database. Changing the unattend file on the hard drive will not update the unattend file saved in the task. To utilize a new version of an unattend file you need to create a new task that uses that unattend file. An existing deploy image task will update the unattend file used when you choose an image.
Applies To
Deployment Solution 7.1
Deployment Solution 7.5
