ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
KNOWN ISSUE: Link to Problem does not work in confirmation window when adding an incident to problem.
Article ID: 157726
ServiceDesk
Incident Management: Link to Problem does not work in confirmation window when adding an incident to problem.
In an incident you can use the the smart task to relate an existing problem to the incident:
Tasks and Actions > Change and Problem Management Tools > Create or Relate to Problem
You will get a confirmation screen titled 'Added to Problem' with a link 'Click here to view progress and status'. This link does not open the Problem as expected, but will open a blank page.
The link that is hardcoded is invalid. The page link is using was removed in ServiceDesk 7.5 (compared to ServiceDesk 7.1 SP2 whereit existed).
This issue is fixed in Workflow 7.6.
Workaround:
The necessary page file is attached (ProcessReportDetails1.aspx). Copy this file to \ProcessManager\Reports folder under ServiceDesk install location (Default location: %programfiles%\Symantec\Workflow\ProcessManager\Reports).
Applies To
ServiceDesk 7.5
ProcessReportDetails1.aspx get_app
