Can Web Viewer 11.5 utilize a MSA account or Machine ID so passwords do not need to be changed?
Article ID: 15731
Updated On: 10-09-2023
Output Management Web Viewer
We are currently using a local SQL account and do not want to have to change passwords every 120 days due to our security requirement.  It is not an option to have a non expiring SQL local account.  We are looking for alternatives.
Is it possible for  Web Viewer 11.5 to utilize a MSA account or Machine ID so passwords do not need to be changed?
MS SQL Server
No.  The SQL password is stored encrypted in the Windows Registry and an MSA account will not work and neither will the machine id.
