YCRTWS ERROR Y2W2029 The YCRTWS failed Path to program object not valid or program object does not exist
Article ID: 15711
Updated On: 06-30-2025
CA 2E
When calling the command YCRTWS I get this *ERROR : Y2W2029 - The YCRTWS failed. Path to program object not valid or program object does not exist.
What could be causing this?
CA 2E 8.7 and higher
The associated program cannot handle iASPs(independent auxiliary storage pools).
CA 2E is currently not certified to run on iASPs.
You would need to change your storage type of the associated objects for CA 2E web service instance.
If your objects have nothing to do with iASPs, please contact Broadcom Support.
