ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
DS Web Console on 2008 R2 does not work with .NET 4.0
Article ID: 157100
Deployment Solution
The DSWeb in DS  6.9 SP5 MR2 will work on .NET  4.0. When it is on a 2008 R2 server however, the web console will error with a 500.24 error (when using Default or Integrated Mode) or 404.2 error (when using Classic Mode).
(When using DefaultAppPool or ASP.NET v4.0)
HTTP  Error 500.24 - Internal Server Error
An ASP.NET setting has been detected that does not apply in Integrated managed pipeline mode.
Module ConfigurationValidationModule
Notification BeginRequest
Handler PageHandlerFactory-Integrated-4.0
Error Code 0x80070032
Requested  URL  http://localhost:80/DSWeb/default.aspx
Physical Path C:\Program Files (x86)\Altiris\eXpress\Deployment Web Console\DSWeb\default.aspx
Logon Method Not yet determined
Logon User Not yet determined
(When using ASP.NET v4.0 Classic)
HTTP Error 404.2 - Not Found
The page you are requesting cannot be served because of the ISAPI  and CGI  Restriction list settings on the web server.
Module IsapiModule
Notification ExecuteRequestHandler
Handler PageHandlerFactory-ISAPI-4.0_32bit
0x800704ec
Logon Method Negotiate
Logon User SERVER\Administrator
Up to Deployment Server 6.9 SP5 MR2 only IIS6 was supported for the DSWeb console.
This will be resolved in DS 6.9 SP5 MR3. For DS 6.9 SP5 MR2, run the attached script in a command prompt in the following manner:
wscript.exe "<enter the path of script file attached>" "<physical path of the DSWeb directory>" "<webroot path for DSweb>"
For example: wscript.exe "C:\Temp\InstallWebApp.vbs" "C:\Program Files\Altiris\eXpress\Deployment Web Console\ DSWeb" "IIS://localhost/W3SVC/1/ROOT/DSWeb"
Applies To
Deployment Solution Version: DS 6.9 SP5 MR2
Server Operating System: Windows Server 2008 R2
.NET  4.0
InstallWebApp.vbs get_app
