This article describes how to perform a batch conversion of Scan Engine (SSE) 5.2.x and Protection Engine (SPE) 7.0.x LOG and DAT files into Comma Separated Values format.
Supported Scan Engine versions: 5.2.8, 5.2.10, 5.2.11, 5.2.13, 5.2.14, 7.0.0, 7.0.1, 7.0.2
REQUIREMENTS
In order for this tool to run, please make sure that the "java.exe" executable is added to the %PATH% system environment variable.
LOG files
DAT files
Scan Engine "statistics" DAT files are already in CSV format and can just be easily renamed with CSV extension.
However, in versions prior to 5.2.11, the headers are in an erroneous format.
Therefore, it is recommended to use only Scan Engine versions equal or above 5.2.11.
Alternatively, please refer to the articles listed in the "Related Articles" section of this page.
