You require detailed power comsumption metrics to plan your Symantec Web Gateway (SWG) appliance installation.
Dell PowerEdge R310 with Dell Energy Smart 400W Power Supply
Form Factor
1 U
Available Processor Sockets
1
Available DIMM Slots / Max Memory Capacity
Jun-48
ECC and/or Fully Buffered DIMMs
Yes
Available Expansion Slots
2 PCI-E
Minimum and Maximum # of Hard Drives
0 to 4
Redundant Power Supply Capable?
Yes
Power Supply Make and Model
A400E-S0
Power Supply Output Rating (watts)
400 (per power supply)
Minimum and Maximum # of Power Supplies
2
Input Power Range (AC or DC)
100-240VAC
Power Supply Efficiency at Specified Loadings (per power supply)
77.3%@10%, 84.6%@20%, 89.5%@50%, 88.6%@100%
Power Supply Power Factor at Specified Loadings1 (per power supply)
Operating Systems Supported2
Microsoft Windows Server 2003 and 2008
Microsoft Windows Essential Business Server 2008 Microsoft Windows Small Business Server 2008 Red Hat Enterprise Linux 4 and 5 SUSE Linux Enterprise Server 10 and 11 |
Installed Operating System for Testing
Microsoft Windows Server 2008
Microsoft Windows Essential Business Server 2008 Microsoft Windows Small Business Server 2008 Red Hat Enterprise Linux 4 and 5 Citrix XenServer 5.x Vmware ESX Server 3.5 SUSE Linux Enterprise Server 10 and 11 Sun Sol |
Power Data
Minimum
Typical
Maximum
Idle Category (1S and 2S only)
Category B: Managed Single Installed Processor (1P) Servers
ENERGY STAR Idle Power Allowance (1S and 2S only)
85
93
169
Measured Idle Powers (watts)
68.1
79.3
161.6
Power at Full Load (watts)
87.6
116.6
242.1
Benchmark/Method Used for Full Load Test
Sandra Dhrystone isse 4.2
Test Voltage and Frequency for Idle and Full Load Test
115 V/60 Hz
Range of Total Estimated Energy Usage ** (kWh/year)
1,193 to 1,534
1,389 to 2,042
2,832 to 4,242
Link to Detailed Power Calculator (if available)
Full Details regarding Benchmark, Temperature and Thermal Power refer to the ENERGY STAR Power and Performance Data Sheet for Dell PowerEdge R310 with Dell Energy Smart 400W Power Supply
Bypass NIC Type:
PEG2BPI5-SD-ROHS bypass NIC:
Power Consumption
Normal Mode:
Max
4 W, 0A at 12V, 1.21A at 3.3V: Typical all ports operate at 1000Mbit/s.
Typical
1.8W, 0A at 12V, 0.54A at 3.3V: Typical all ports operate at 100Mbit/s.
Min
1.42W, 0A at 12V, 0.43A at 3.3V: Typical all ports operate at 10Mbit/s.
No Link
1.03W, 0A at 12V, 0.31A at 3.3V: Typical No link at all ports.
Bypass Mode
1.18W, 0.1A at 12V and 0.32A at 3.3V: Typical Bypass Mode
Dell PowerEdge R710 with Dell High Output 870W Power Supply
Form Factor
2U
2
18/192 GB
Yes
4 PCI-E
0 to 8
Yes
Dell Energy Smart A870P
870
1 or 2
100-240VAC
81.5%@10%, 88.1%@20%, 92%@50%, 91.5%@100%
VMWare ESXi 3.5
Microsoft Windows Server 2003 | ||
Power Data
Minimum
Typical
Maximum
69
224
606
59
122.3
236.3
101.8
266.8
430.9
115 V/60 Hz
1,034 to 1,784
2,143 to 4,674
4,140 to 7,549
Full Details regarding Benchmark, Temperature and Thermal Power refer to the ENERGY STAR Power and Performance Data Shee for Dell PowerEdge R710 with Dell Energy Smart 570W Power Supply
Bypass NIC Type:
PEG4BPI-SD-ROHS bypass NIC
Power Consumption
Normal Mode:
Max
9.54W, 0.3A at 12V and 1.8A at 3.3V: Typical all ports operate at 1000Mbit/s.
Typical
6.27W, 0.3A at 12V and 0.81A at 3.3V: Typical all ports operate at 100Mbit/s.
Min
5.68W, 0.3A at 12V and 0.63A at 3.3V: Typical all ports operate at 10Mbit/s.
No Link
5.58W, 0.3A at 12V and 0.6A at 3.3V: Typical No link at all ports.
Bypass Mode
5.98W, 0.3A at 12V and 0.72A at 3.3V: Typical
