How to Block USB flash Drive and External Hard Disk using SEP.
Article ID: 156447
Endpoint Protection
In the Symantec Endpoint Protection Manager, open Policies, then click Application and Device Control.
  1. Open an existing policy or click Add an Application and Device Control Policy.
  2. Click on the Device Control tab.
  3. Under the Blocked Devices section click the ADD button and select the Disk Drives option.
  4. Click OK to save the changes and assign policy.
