Autosys instances will not stay up after PropleSoft plugin installation.
Autosys instances will not stay up after PropleSoft plugin installation. The following error was found in both nohup.err and default_agent.log:
07/25/2017 14:07:11.018 EDT-0400 5 main.MainThread.CybPsPluginDriver.runApplication[:104] - CybPsPluginDriver Build 20 starting
07/25/2017 14:07:11.533 EDT-0400 1 main.MainThread.CybAgentDriver.runApplication[:373] - cybermation.library.plugins.CybPluginException: Plugin instantiation failed at cybermation.agent.plugins.manager.CybPluginManager.invokePluginMethod(CybPluginManager.java:323)
at cybermation.agent.plugins.manager.CybPluginManager.loadPlugins(CybPluginManager.java:448)
at cybermation.agent.CybAgentDriver.runApplication(CybAgentDriver.java:303)
at cybermation.agent.CybAgentDriver.main(CybAgentDriver.java:406)
Caused by: java.lang.reflect.InvocationTargetException: null
at sun.reflect.NativeMethodAccessorImpl.invoke0(Unknown Source)
Check the System Agent log directory for the peoplesoft.log
Most likely it is a problem with the installation of the ps.pak Peoplesoft Plugin. The log will tell you what part of the install is incorrect.
IE (Database not found, User login Incorrect, Permissions etc...)
