Index (zero based) must be greater than or equal to zero and less than the size of the argument list
Article ID: 152459
IT Management Suite
I am getting the following error: "Index (zero based) must be greater than or equal to zero and less than the size of the argument list" (cfgDiscovery.aspx error).
Priority: 1
Date: 19.02.2006 15:20:43
Tick Count: 8837750
Host Name: ServerNAME
Process: w3wp.exe (3056)
Thread ID: 320
Module: AltirisNativeHelper.dll
Source: global.asax
Description: Unhandled exception.  Type=System.FormatException Msg=Index (zero based) must be greater than or equal to zero and less than the size of the argument list.
StackTrace=
   at System.Text.StringBuilder.AppendFormat(IFormatProvider provider, String format, Object[] args)
   at System.String.Format(IFormatProvider provider, String format, Object[] args)
   at Altiris.NS.UI.cfgDiscoveryDomain.LocalizeFormattedErrorString(String strErr)
   at Altiris.NS.UI.cfgDiscoveryDomain.Page_Load(Object sender, EventArgs e)
   at System.Web.UI.Control.OnLoad(EventArgs e)
   at _ASP.cfgDiscoveryDomain_ascx.OnLoad(EventArgs e)
   at System.Web.UI.Control.LoadRecursive()
   at System.Web.UI.Page.ProcessRequestMain()
Unknown.
The issue was resolved in R2 for NS 6.0 Sp3. The work around is to switch to English IE language settings.
Applies To
NS 6.0 SP3
2x Windows 2003 SP1 German operating system—SQL 2000 SP4 German
1x Windows 2003 SP1 English operating system—SQL 2000 SP3 English
German IE Language Settings
