Does CA Output Management Web Viewer have a dependency on Adobe Flash Player
Article ID: 15229
CA Output Management Document Viewer
Does CA Output Management Web Viewer have a dependency on Flash Player? This is coming up due to a security vulnerability identified for Flash Player.
Adobe Flash Player
CA Output Management Web Viewer 11.5, 12.0 or 12.1 does not require or install Adobe Flash Player.
Feedback
