Need a help to enabling IFCID 25 and route to SMF
Article ID: 15111
Bind Analyzer for DB2 for z/OS SQL-Ease for DB2 for z/OS SYSVIEW Performance Management Option for DB2 for z/OS Plan Analyzer for DB2 for z/OS Subsystem Analyzer for DB2 for z/OS
How to route IFCID 25 records to SMF
Currently we have the IFCID 25 records enabled via CA Sysview for DB2 and collected in OP1. But we need to route them to SMF.
Is there any way to route the IFCID 25 records collected to SMF via CA Sysview for DB2?
z/os DB2
CA Sysview for DB2 does not route Ifcid records to SMF. If you have that requirement you will have to start a Trace yourself routing the Records to SMF.
