To mitigate the risks that Decomposer vulnerabilities pose, the following hotfixes are available for Symantec Protection Engine.
You must apply the appropriate hotfix attached in this article to your Symantec Protection Engine version.
Sr. No. |
SPE Version |
Hotfix Number |
Download |
1 |
SPE 7.0.0 |
HF02 |
SPE_7.0.0_HF02.zip |
2 |
SPE 7.0.1 |
HF02 |
SPE_7.0.1_HF02.zip |
3 |
SPE 7.0.2 |
HF11 |
SPE_7.0.2_HF11.zip |
4 |
SPE 7.0.3 |
HF03 |
SPE_7.0.3_HF03.zip |
5 |
SPE 7.0.4 |
HF02 |
SPE_7.0.4_HF02.zip |
6 |
SPE 7.0.5 |
HF02 |
SPE_7.0.5_HF02.zip |
7 |
SPE 7.5.0 |
HF06 |
SPE_7.5.0_HF06.zip |
8 |
SPE 7.5.1 |
HF06 |
SPE_7.5.1_HF06.zip |
9 |
SPE 7.5.2 |
HF08 |
SPE_7.5.2_HF08.zip |
10 |
SPE 7.5.3 |
HF04 |
SPE_7.5.3_HF04.zip |
11 |
SPE 7.5.4 (AWS Release) |
HF02 |
SPE_7.5.4_HF02.zip |
12 |
SPE 7.5.5 |
HF01 |
SPE_7.5.5_HF01.zip |
13 |
SPE 7.8.0 |
HF03 |
SPE_7.8.0_HF03.zip |
For the detailed instructions on how to apply the hotfix, see the Readme.txt file in the zip file that you downloaded.
For more information about the Decomposer vulnerabilities, see Advisory-I and Advisory-II.
To check if the hotfix is applied (Decomposer version) on SPE 7.8:
export LD_LIBRARY_PATH=/opt/SYMCScan/bin./xmlmodifier -s //configuration/Logging/LogLocal/@loglevel 4 configuration.xmlXMLModifier.exe -s //configuration/Logging/LogLocal/@loglevel 4 configuration.xmlTo check if the hotfix is applied (Decomposer version) on SPE 7.0.x and SPE 7.5.x:
export LD_LIBRARY_PATH=/opt/SYMCScan/bin./xmlmodifier -s //configuration/logging/loglocal/@value 4 configuration.xmlXMLModifier.exe -s //configuration/logging/loglocal/@value 4 configuration.xmlNote: You must revert the log level back to your previous settings after checking the Decomposer version.
