Ghost Solution Suite 3.X Automation Folder User Guide
Article ID: 150208
This document covers the new Automation Folder functionality introduced in GSS 3.0 HF3.
Ghost Solution Suite 3.0 HF3 and later.
The Topic Covered are:
  • Chapter 1 - Getting Started with the Automation Folder
  • Chapter 2 - Installing the Automation Folder on a Client
  • Chapter 3 - Verifying the Automation Folder on a Client
  • Chapter 4 - Automation Partition Packages
Note: Only WinPe OS's are supported at this time for use as automation folders.
Ghost 3.0 HF3 Automation Folders.pdf get_app
