The article lists the upgrade paths that are supported for different versions of Symantec Protection Engine of NAS and CS.
Symantec Protection Engine version 7.0.X
Upgrade From Version |
Upgrade To Version
(Supported)
Upgrade To Version
(Not Supported)
7.0.0 | 7.0.1, 7.0.2, 7.0.3, 7.0.4, 7.0.5, 7.5.0, 7.5.1, 7.5.2, 7.5.3, 7.5.5 | - |
7.0.1 | 7.0.2, 7.0.3, 7.0.4, 7.0.5, 7.5.0, 7.5.1, 7.5.2, 7.5.3, 7.5.5 | - |
7.0.2 | 7.0.3, 7.0.4, 7.0.5, 7.5.0, 7.5.1, 7.5.2, 7.5.3, 7.5.5 | - |
7.0.3 | 7.0.4, 7.0.5, 7.5.1, 7.5.2, 7.5.3, 7.5.5 | 7.5.0 |
7.0.4 | 7.0.5, 7.5.2, 7.5.3, 7.5.5 | - |
7.0.5 | 7.5.3, 7.5.5 | - |
Symantec Protection Engine version 7.5.X
Upgrade From Version | Upgrade To Version (Supported) | Upgrade To Version (Not Supported) |
7.5.0 | 7.5.1, 7.5.2, 7.5.3, 7.5.5 | - |
7.5.1 | 7.5.2, 7.5.3, 7.5.5 | - |
7.5.2 | 7.5.3, 7.5.5 | - |
7.5.3 | 7.5.5 | - |
