ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
CA Top Secret SECCACHE and SWAP Control Option settings
Article ID: 14670
Top Secret Top Secret - LDAP
TSS9999E CA-TSS SECURITY SVC ABEND S0D5 IN TSSDSSRV+xxx (intermittently) when users connect to an application.
What would cause this?
Release:
Component: TSSMVS
If the SECCACHE Control Option feature is used, the Control Option SWAP(NO) must also be set.
The combination of using SECCACHE with SWAP(YES) set could result in S0D5 abend in module TSSDSSRV.
Change the CA Top Secret control option from SWAP(YES) to SWAP(NO) to prevent this issue.
