Issue running DEVTEST Portal from different machine
Article ID: 14656
Updated On: 10-12-2023
CA Application Test CA Continuous Application Insight (PathFinder) Service Virtualization
When trying to run Portal from different machine it is not starting.
I have ED, Registry, Coordinator , Simulator  is on one machine   And, Portal  on another machine.
What configurations are needed?
All supported DEVTEST builds.
In the phoenix.properties of the portal machine just set these properties:
registry.host=<Registry hostname>
registry.port=2009
registry.portal.port=1505
# registry.https.enabled=true    // enable this only if you have SSL between components
phoenix.port=1507
#phoenix.https.enabled=true    // enable this only if you have SSL between components
In your local.properties set this:
lisa.registryName=tcp://<Registryhost>:2010/Registry
Please make sure  you do not have any network / firewall issues.
