ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Difference between legacy and huge landscape handles for Spectrum
Article ID: 145771
CA SpectrumCA eHealth
What are the differences between a legacy and huge landscape handle for SpectroSERVER?
The major difference is the amount of models that can be modeled on a single landscape. With legacy you are limited to the amount of models that can be modeled requiring more SpectroSERVERs for larger environments.
With HUGE landscape handle you are able to model more models per landscape, thus reducing the overall footprint of Spectrum in your environment. Broadcom suggests huge landscape where applicable.
