Problem with alter on a tablespace
Article ID: 145593
Updated On: 05-26-2020
RC Compare for DB2 for z/OS Database Management for DB2 for z/OS - Administration Suite Endevor Interface for Db2 for z/OS Endevor Interface for Remote Db2 for z/OS RC/Extract for DB2 for z/OS RC/Migrator for DB2 for z/OS RC/Merger for DB2 for z/OS RC/Query for DB2 for z/OS RC/Secure for DB2 for z/OS RC/Update for DB2 for z/OS
RC Query using the alter function on a partitioned Tablespace
When we press F3 without any modification on the panel, we don't go back to the first screen but we got the alteration analysis screen
and we have to enter the cancel command to go back to the TS list.
Release : 20.0
Component : CA RC/Query for DB2 for z/OS
product design
This is working as designed.
Users have to enter the command CANCEL to come out of the alter panel.
PF3 will generate the ALTER DDLs syntax.
