USM does not display NFA data for interfaces
Article ID: 144689
USM is not displaying NFA data for interfaces and nfa_inventory log captures the following error:
[Connection tester - 0, nfa_inventory] getResourceProperty: host=wv1itnfawb01.eapps.ncads.net
[Connection tester - 0, nfa_inventory] getResourceProperty: port=80
[Connection tester - 0, nfa_inventory] **** NFA API URI: http://%nfarconsolehostname%t:80/ReporterDataSource/InventoryWS.svc/GetNFAUrls
[Connection tester - 0, nfa_inventory] HTTP request to NFA status line: HTTP/1.1 500 Internal Server Error
[Connection tester - 0, nfa_inventory] Response from HTTP request to NFA was: 500
[Connection tester - 0, nfa_inventory] Exception occurred while attempting HTTP request to NFA at %nfarconsolehostname%
[Connection tester - 0, nfa_inventory] org.apache.http.client.HttpResponseException: Response from API was not 200 OK. The status code was: 500
 at com.nimsoft.probe.network.nfa_inventory.util.RestfulClient.executeHttpRequest(RestfulClient.java:116)
 at com.nimsoft.probe.network.nfa_inventory.util.RestfulClient.executeGet(RestfulClient.java
Release : 9.2.0
Component : UIM - NFA_INVENTORY
NFA Console was not completely configured with HTTP which is a requirement for the nfa_inventory probe.
1. Manually load the suspect link in a browser (http://%nfarconsolehostname%:80/ReporterDataSource/InventoryWS.svc/GetNFAUrls) and this failed with "Server Error in '/reporterDataSource' Application. Could not find a base address that matches the scheme https for the endpoint with the WebHttpBinding, Registered base address scheme are http
2. Edited the D:\CA\NFA\REPORTER\NetQoS.ReporterAnalyzer.WebService\web.config file and changed the following section as followed:
    <bindings>
      <webHttpBinding>
        <binding name="CustomBinding">
          <security mode="None">
            <transport clientCredentialType="None"/>
          </security>
        </binding>
      </webHttpBinding>
    </bindings>
3. Run iisreset from the commad line
