Error "Refused to frame..." embedding Power BI links /dashboard in HTML portlet
Article ID: 144323
Updated On: 09-25-2023
Clarity PPM SaaS Clarity PPM On Premise
The PowerBI sign-in link and then subsequent iFrame dashboard will not show up unless you disable X-Frame Headers via an extension. Error in browser trace references:
Refused to frame 'https://example.com/' because it violates the following Content Security Policy directive: "frame-src 'self' techdocs.broadcom.com fonts.googleapis.com cdnjs.cloudflare.com data:".
Release :  All Supported Releases
SaaS Customers, please contact Broadcom support for assistance with this issue.
Configure the Content Security Domains:
1. Follow the KB to update the CSP:
Content Security Domain update (with Command Prompt and in Clarity database)
2. Restart the services
