After running allocate from estimates, ETC and allocation do not match:
Steps to reproduce:
Results: The ETC in the team tab show correct at 55 hours, but the allocation is increased to 64.42. Why is the allocation higher than the ETC? Where is this coming from?
This is due to the Round Allocations to Nearest % being set to a higher amount such as 25%. This is a setting that is set out of the box that performs a rounding on the allocations.
Release : All
Component : CLARITY RESOURCE MANAGEMENT
To change the default value:
