Fast Load should fail with Conversion errors
Article ID: 144117
Updated On: 01-30-2020
Database Analyzer for DB2 for z/OS Fast Unload for DB2 for z/OS Fast Check for DB2 for z/OS Fast Index for DB2 for z/OS Rapid Reorg for DB2 for z/OS
CA FASTLOAD job needs to fail with Conversion errors like IBM Load?
Release : 20.0
Component : CA Fast Load for DB2 for z/OS
Fast Load ran fine, this is by design, If you want Fast Load to fail, we document for Release R20:
The DISCARD-ERROR keyword specifies the return code and action to take when discard errors are encountered.
DISCARD-ERROR [
NONE
|ABEND|RC
xx
If you code abend, the Fast Load job with; U0101
