UIM - memory leak with hub 9.20HF6 and robot 9.20HF7
Article ID: 143788
NIMSOFT PROBES DX Infrastructure Management
We are running UIM 9.2 with hub 9.20HF6 and robot 9.20HF7 and we are seeing a memory leak of the hub process.
A restart of the Nimsoft Service fixes the issue.
The hub memory leak was caused by robot_update-9.20HF7
Release : 9.2.0
hub 9.20HF6
9.20HF7
Component : UIM - SNMPCOLLECTOR
Deployed robot_update-9.20HF9+ which is available in CA Unified Infrastructure Management Hotfix Index page
https://techdocs.broadcom.com/us/product-content//recommended-reading/technical-document-index/ca-unified-infrastructure-management-hotfix-index.html?r=2
