DUAS: "uxlst prv" wrong output when using Offsets Rules
Article ID: 143334
Automic Dollar Universe
uxlst prv command output is not correct if the task contains Offset Rules : we could see dates of jobs which were not inside the range asked by the command.
UVC Simulation of the same Task works fine.
Release : 6.x
Component : DOLLAR UNIVERSE
Two issues with command "uxlst prv" :
- Offset Rule was incremented for some reason with 1
- Filters were not taken into account correctly (hours/date)
Workaround:
Modify Tasks properties ( change the Rule and remove the Offset Rule) or use Univiewer Console to Simulate the Task Schedule.
Solution :
Update to a fix version listed below or a newer version if available.
Fix version(s):
Component: Application.Server
Dollar Universe 6.10.21 - Released 15th January 2020
