Fault Correlation engine probe not starting - red state
Article ID: 143107
NIMSOFT PROBES DX Infrastructure Management
Hello,
We updated from 8.51 to 9.0.2 then to 9.2, with all the problems on the middle that brings but finally made it.
But the probe in mention dont start, i tryed to .. restart, deactivate, redeploy from archive, delete it and reinstar from scrach.... and nothing, it dosent leave any log also thats the worst part...
The versi├│n we are using is 9.1
This probe is necesarito be running at all? We dont notice any impact so far.
Release : 9.1.0
Component : UNIFIED INFRASTRUCTURE MGMT
This probe has some Dependencies with this other probes:
topology_agent
relationship_services
net_connect
topology_fault_correlation
After that the Fault Correlation engine probe started successfully
https://techdocs.broadcom.com/content/broadcom/techdocs/us/en/ca-enterprise-software/it-operations-management/unified-infrastructure-management/9-0-2/topology-and-root-cause-analysis0.html
