Our colleague on the field explained that this new customer defined some userIDs on UAMS (User ID Access Maintenance System)
to start up the NetMaster region. Now they want to use their RACF userIDs in NetMaster. Help is needed to choose the NM Security
Solution for them to use.
OS : z/OS
Release : 12.2
Component : Unicenter NetMaster Management Services
