"Create forecast" option when right-clicking a task in the Process Assembly perspective is not visible to the users that do not have "Access to Transport Case" Privilege
Defect
Release : 12.0
Component : AUTOMIC WEB INTERFACE, AUTOMATION ENGINE
Upgrade to one of the following versions:
Automation Engine 12.1.X
Automation Engine 12.2.X
Automation Engine 12.3.X
Workaround:
Add "Access to Transport Case" Privilege for a user/usergroup in order to have an option to create a Forecast.
