CA API Gateway in Container Form Factor in Version: 9.4.00_20190528.
I'm trying to obfuscate the default server for the Gateway HTTP listener as describe in this documentation:
Adding the following advanced property setting for the listen port: server=www
Nevertheless the Gateway still returns the Header: Server: CA-API-Gateway/9.0 to the client.
Release : 9.4 10.X 11.X
Component : API GTW ENTERPRISE MANAGER
For some listen ports the advanced property configuration was "Server=www" instead of "server=www". Everything needs to be in lowercase letters in order to work correctly.
