WPs do not start if hostname=*OWN is set in the ucsrv.ini.
20191004/164343.005 - U00003412 Agent 'getaddrinfo("*OWN") - No such host is known. ' logged on (Client connection='').
20191004/164343.005 - No such host is known.
20191004/164343.005 - |
20191004/164343.005 - U00003128 Server 'AUTOMIC#CP001' is removed from server table (MQSRV). Reason 'unreachable'.
Because the WPs do not start, this can also cause users to be unable to connect to the AWI.
Defect.
Release : 12.3
Component : AUTOMATION ENGINE
Update to a fix version listed below or a newer version if available.
Fix status: Fixed
Automic Automation Engine 12.3.3 - Available
Public short description EN:
Automation Engine does not start if the parameter hostname is set to *OWN in ucsrv.ini
Public description EN:
A problem has been fixed where the successful start of the Automation Engine failed if hostname=*OWN
This special configuration parameter was not replaced by the actual name of the host.
Therefore CPs cannot get a connection to WPs and it is not possible to login to the system.
